[OpenLayers-Users] Label alignment on different browsers
Andreas Hocevar
ahocevar at opengeo.org
Fri Jul 20 11:30:01 PDT 2012
No - your html has a completely different doctype:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
It is not even HTML, it is XHTML. And it is not the doctype that will
put IE9 in standards mode. So what you want to do is change the above
doctype to just
<!DOCTYPE html>
Andreas.
On Fri, Jul 20, 2012 at 3:08 PM, Nuno Magalhães <nuno.magalhaes at inov.pt> wrote:
> Hello,
> If you check the original posted html, you'll see it has already that tag.
> But results are different between IE9 and Firefox.
> Regards,
> Nuno Magalhães.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Label-alignment-on-different-browsers-tp4989513p4989655.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
