[OpenLayers-Users] wmsgetfeaureinfo doesn't work with a literal url
Giuseppe De Marco peppelinux at yahoo.it
Fri Jul 27 01:31:51 PDT 2012
Hi phill, thank you
> So, firstly, you say wmsgetFeatureinfo doesnt fire at all. What do you mean by that?
I mean that the click doesn't produce any event, as I can see in firebug it seems like I've not clicked at all !
> Have you used firebug to trace into where getfeatureinfo is called? Or are you using the Net monitor to see that wmsgetfeature POSTs are not being generated?
I use Net monitor, the POST action is not generated at all.
If I use an external IP, in firebug I can seen "allow origin.. etc.".
If I use the ip address with the same origin it works.
If I use a literal hostname it doesn't work.
I can also see the httpd logs, so I can effectly see if a connection is estabilished or not.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120727/294a0ab0/attachment.html>
