[OpenLayers-Users] Problems with labels
Alexandre Dubé
adube at mapgears.com
Fri Jul 27 05:32:43 PDT 2012
Hi Dariusz,
I had the same issue back in 2010. Here's the workaround I used to
bypass the issue :
layer.renderer.textRoot = layer.renderer.vectorRoot;
That way, both text and geometry are rendered in the same container and
avoid the overlapping labels. See my [original post] and also the small
[demo] containing the fix, in which you need to zoom out a little to see
features with their labels on top of others.
As mentionned, this is a workaround. It didn't work well in IE8 with WML
so I had to emulate IE7. If you find something better, let us know.
HTH,
Alexandre
[original post]
http://osgeo-org.1560.n6.nabble.com/Overlapping-labels-td3924879.html
[demo] http://bs-dev2.mapgears.com/webmap/
On 12-07-26 04:50 PM, Dariusz Bączkowski wrote:
> Hello,
> I have problems with labels. It looks like this:
> http://getmt.pl/labels.png
> I would like it to have graphics cover labels according to z index and last
> drown order. Right now it looks like all graphics are being drawn at once and
> then all labels at once. This is SVG renderer.
> With Canvas i get something like this (offset not working):
> http://getmt.pl/labels_canvas.png
> code is not changed only renderers order.
> Is there something I can do to fix thoes issues?
Alexandre Dubé
Mapgears
www.mapgears.com
