[OpenLayers-Users] Add labels above the lines.
adidas
xkadidas at gmail.com
Fri Jul 27 05:38:50 PDT 2012
27.07.2012 15:28, Alexandre Dubé пишет:
> Hi Adidas,
> Layers are displayed on top of each other in the order they were added
> to the map : first added is at the bottom, last is on top. The
> exception to that rule are layers with baseLayer:true property set,
> which are always at bottom.
> Try to look in what position your label layer is added and push it to
> the end.
> HTH,
> Alexandre
> On 12-07-27 06:54 AM, adidas wrote:
>> Hello! How to add labels above the lines?
>> Labels are added as follows:
>> var styleMarkersLabels = new OpenLayers.Style( // стили для надписей
>> узлов
>> strokeWidth: 2,
>> labelYOffset: 10,
>> label: "${label}",
>> fontColor: 'red',
>> fontSize: 9,
>> fontWeight: "bold",
>> labelOutlineColor: "black",
>> labelOutlineWidth: 1
>> var vectorPoint = new OpenLayers.Layer.Vector("Узлы (надписи)",
>> styleMap: new OpenLayers.StyleMap(
>> { "default": styleMarkersLabels,
>> "select": { pointRadius: 20}
>> map.addLayer(vectorPoint);
>> function addPoint(lon, lat, title, ident, layr){
>> var ttt = new OpenLayers.LonLat(parseFloat(lon), parseFloat(lat));
>> ttt.transform(new OpenLayers.Projection("EPSG:4326"), new
>> OpenLayers.Projection("EPSG:900913"));
>> for (var k = 0; k < layr.features.length; k++) {
>> if(layr.features[k].attributes.PointId==ident) {
>> layr.features[k].move(ttt);
>> layr.features[k].attributes.label=title;
>> return false;
>> var point0 = new OpenLayers.Geometry.Point(parseFloat(lon),
>> parseFloat(lat));
>> point0.transform(new OpenLayers.Projection("EPSG:4326"), new
>> layr.addFeatures(new OpenLayers.Feature.Vector(point0, { label:
>> title, name: title, PointId: ident }));
>> var lat2, lon2, title, ident;
>> for (l = 0; l < nodesLabels_Count; l++) {
>> lat2 = nodesLabels_arr[l]["points"][0]["lat"];
>> lon2 = nodesLabels_arr[l]["points"][0]["lon"];
>> title = nodesLabels_arr[l]["title"];
>> ident = nodesLabels_arr[l]["ident"];
>> addPoint(lon2, lat2, title, ident, map.layers[4]);
>> But i got it: http://softez.pp.ua/labels.PNG
>> Map here: http://softez.pp.ua/fiberms/fiberms/map.php
>> Thanks!
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
The layer of labels is ABOVE all.
