[OpenLayers-Users] Point symbolizer: triangle + orientation line
Gabriel Vatin
gabriel.vatin at mines-paristech.fr
Fri Jul 27 07:18:54 PDT 2012
Hello,
I'd like to represent mobile objects (WFS layer of points) with a
triangle, and a line to show the direction and speed of it. Right now, I
can use the default "triangle" symbolizer :
symbolizer: {
rotation: '${heading}',
pointRadius: 6.5,
graphicName: 'triangle',
strokeColor: 'white',
fillColor: color,
strokeOpacity: 0.3,
strokeWidth: 2,
fillOpacity: 0.7
Then I use the rotation attribute to turn the trangle. The triangle
object is a isosceles triangle, but it is so small that we can't really
see its orientation. So is there a method to draw a triangle and a line
at the top of it to show the direction ?
I just tried to add a new WFS layer with the same origin, but an other
symbolizer :
defaultStyleD = new OpenLayers.Style({
pointRadius: 25,
externalGraphic: './img/line.png',
graphicYOffset: -50
The line.png is an image I made myself. If I display the 2 layers at the
same time, that's the kind of result that I want to see... but this is
only a trick, and not a real good way to answer my problem !
Do you have any idea ?
Thanks,
Gabriel
