[OpenLayers-Users] MapIgniter Project
Christian Ledermann christian.ledermann at gmail.com
Tue Jul 31 05:09:24 PDT 2012
On Tue, Jul 31, 2012 at 2:40 PM, mafonso <mafonso333 at gmail.com> wrote:
> Thank you Christian for the enlightenment. I will check those projects and
> extract a detailed comparison.
> At a first sight, Plone is based on Python.
and on the zope framework.
> GeoNode is based on Java.
actually it is a mix of django (python), postgis,  geoserver.  geonetwork (java)
> CartoDB is limited on Free Plan.
Cartodb is mainly build on Ruby, Nodejs, Postgis
It is not obvious from their man page but it is open source
https://github.com/Vizzuality/cartodb
> MapIgniter is based on PHP, Open Source,
all of the above are open soure too.
Best Regards,
Christian Ledermann
Nairobi - Kenya
Mobile : +254 702978914
If you save the living environment, the biodiversity that we have left,
you will also automatically save the physical environment, too. But If
you only save the physical environment, you will ultimately lose both.
1) Don’t drive species to extinction
2) Don’t destroy a habitat that species rely on.
3) Don’t change the climate in ways that will result in the above.
