[OpenLayers-Users] Re: Combining layers with different SRS -
intentionally - is failing
cheesybiscuits
thomaschristian at gmail.com
Fri Mar 2 12:24:01 EST 2012
Thanks Andreas I will give this a try when I next have access to the data,
although this does look very similar to my existing code. When you say 'a
recent build' do you mean more recent than 2.11 Release?
It's good that OpenLayers will treat 900913 and 3875 as the same SRS, but
much to my ongoing irritation I have to use a tweaked version of 3785, so
OpenLayers cannot help me in the same way.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Combining-layers-with-different-SRS-intentionally-is-failing-tp4537869p4539965.html
