[OpenLayers-Users] How to make Openlayers to request the vector
data every manipulation of map
Bartłomiej Burkot
pomiarowiec10 at poczta.onet.pl
Thu Mar 8 10:56:53 EST 2012
Hello,
I think I have exactly the same problem. I have vector layer with many
points-markers. I need to limit the number of fetched points from server
becouse of performance.
The vectorlayer use bbox strategy and protocol HTTP:
weather_points_layer = new OpenLayers.Layer.Vector("Wetterpunkte", {
strategies: [new OpenLayers.Strategy.BBOX({ratio: 1.1})],
protocol: new OpenLayers.Protocol.HTTP({
url: "text_layer_generator/weather_points.php"
The script: weather_points.php limits the number of points using bbox
parameter and LIMIT statement in sql query.
There is the working example: http://mapakrakow.pl/pogoda/test.php
When I zoomin the points are not fetched from server but from browser
cache. Problem is that when you zoomin to - for example Berlin - you
don't see any points. There is not any request in firebug fetching the data.
Running this command:
weather_points_layer.refresh({force:true});
in firebug console Openlayers requests and refreshes the data from
server correctly and shows points over Berlin.
I tryed to change cache-control headers in weather_points.php:
#header("Cache-Control: max-age=2"); // HTTP/1.1
#header("Expires: Sat, 26 Jul 1997 05:00:00 GMT"); // Date in the past
#header("Pragma: Cache"); // required
//header("connection: close");
//Keep-Alive timeout=2, max=100
and add the refresh strategy:
strategies: [new OpenLayers.Strategy.BBOX({ratio: 1.1}), new
OpenLayers.Strategy.Refresh()],
but both didn't helped.
I fond this article:
http://stackoverflow.com/questions/2995238/how-to-refresh-reload-a-kml-layer-in-openlayers-dynamic-kml-layer
But I don't need to refresh vectorlayer in constant time interval but
every time when user manipulates the map.
Has someone experience how to solve this problem?
Thanks for your help.
Bartlomiej Burkot
W dniu 2012-03-07 16:56, Jan Hartmann pisze:
> No, it tried that. According to the documentation, the redraw function
> does not take a parameter.
> Jan
> On 03/07/2012 04:45 PM, Steve.Toutant at inspq.qc.ca wrote:
>> Is this working?
>> vectorLayer.redraw(true);
>> *Jan Hartmann <j.l.h.hartmann at uva.nl>@lists.osgeo.org*
>> Envoyé par : openlayers-users-bounces at lists.osgeo.org
>> 2012-03-07 10:27
>> A
>> openlayers-users at lists.osgeo.org
>> cc
>> Objet
>> [Polluriel potentiel] [OpenLayers-Users] force update markers layer
>> Hi,
>> How do I force a redraw on a markers layer? I have a regular WMS map
>> with markers that have their lonlat-values updated from a database. I
>> can force a redraw of the WMS layer with mergenewparams(), but that
>> is not possible with the markers layer. That means that the when the
>> lonlat values are updated and I move the map, the markers remain in
>> their original positions. Only when I zoom in or out, the marker
>> positions are updated. Can I do something about that?
>> Jan_______________________________________________
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120308/538f320b/attachment.html
