[OpenLayers-Users] RE: using default transparency from service
Andreas Hocevar
ahocevar at opengeo.org
Mon Mar 12 06:59:49 EDT 2012
Maybe your WMS is not configured to use alpha transparency with format
image/png. Your configuration would definitely work fine with
GeoServer.
Andreas.
On Mon, Mar 5, 2012 at 8:08 PM, spiveygb <brett.spivey at nc.gov> wrote:
> Andreas,
> Yes. Here is how I’m building the layer:
> lyrName = new OpenLayers.Layer.WMS(
> layer.title,
> baseUrl,
> layers: layer.name,
> format: 'image/png',
> transparent: true
> isBaseLayer: false,
> singleTile: true,
> ratio: 1,
> transitionEffect: 'resize'
> Brett Spivey
> NC OneMap Programmer
> Center for Geographic Information & Analysis
> Office of the State Chief Information Officer
> 919.754.6591
> [hidden email]
> http://www.cgia.state.nc.us
> Email correspondence to and from this address may be subject to the North
> Carolina Public Records Law and may be disclosed to third parties by an
> authorized state official.
> From: Andreas Hocevar-2 [via OSGeo.org] [mailto:ml-node+[hidden email]]
> Sent: Friday, March 02, 2012 9:48 PM
> To: Spivey, Brett
> Subject: Re: using default transparency from service
> Hi,
> do you have your WMS layer configured with something like
> {layers: "mylayer", transparent: true, format: "image/png"}
> Then things should work.
> Andreas.
> On Wed, Feb 29, 2012 at 9:17 PM, spiveygb <[hidden email]> wrote:
>> When accessing services from ArcGIS Server, either REST or WMS, the layers
>> are opaque although they have some transparency by default. Is there no
>> way
>> to have the layers draw as intended directly from the service? I know I
>> can
>> set opacity when creating the layer but users can add or access
>> services/layers from many different servers (that aren't mine). In other
>> words, I don't know what services or layers they may add. Therefore, I
>> don't
>> want to "assign" a static transparency value for every one of them by
>> default in the code.
>> ________________________________
>> View this message in context: using default transparency from service
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> [hidden email]
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> [hidden email]
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/using-default-transparency-from-service-tp4532730p4541403.html
> To unsubscribe from using default transparency from service, click here.
> NAML
> E-mail correspondence to and from this address may be subject to the North
> View this message in context: RE: using default transparency from service
> Users mailing list
> Users at lists.osgeo.org
Andreas Hocevar
