AW: [OpenLayers-Users] Openlayers circle Polygon on OpenStreetMaps
layer
Arnd Wippermann
arnd.wippermann at web.de
Thu Mar 15 19:02:04 EDT 2012
Try to use a much larger radius for your regular polygon like 10000.
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Fabrizio
Buratta
Gesendet: Donnerstag, 15. März 2012 17:23
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] Openlayers circle Polygon on OpenStreetMaps
layer
I'm trying to create a circle with a defined center and put an icon marker
on it. The code is working if I use images instead of
OpenLayers.Geometry.Polygon.createRegularPolygon. I wasn't able to solve it.
here you find my code:
<html>
<head>
<title>OpenLayers Example</title>
<script src="http://www.openlayers.org/api/OpenLayers.js"></script>
</head>
<body>
<div id="mapdiv"></div>
<script>
map = new OpenLayers.Map("mapdiv");
map.addLayer(new OpenLayers.Layer.OSM());
epsg4326 = new OpenLayers.Projection("EPSG:4326"); //WGS 1984 projection
projectTo = map.getProjectionObject(); //The map projection (Spherical
Mercator)
var lonLat = new OpenLayers.LonLat( -0.1279688 ,51.5077286
).transform(epsg4326, projectTo);
var zoom=6;
map.setCenter (lonLat, zoom);
var mycircle = OpenLayers.Geometry.Polygon.createRegularPolygon(
new OpenLayers.Geometry.Point( lonLat ),
1,
30
var featurecircle = new OpenLayers.Feature.Vector(mycircle);
var vectorLayer = new OpenLayers.Layer.Vector("Overlay");
// Define markers as "features" of the vector layer:
vectorLayer.addFeatures(featurecircle);
var feature = new OpenLayers.Feature.Vector( new OpenLayers.Geometry.Point(
-0.1244324, 51.5006728 ).transform(epsg4326, projectTo),
{description:'info'} ,
{externalGraphic: 'img/marker.png', graphicHeight: 25,
graphicWidth: 21, graphicXOffset:-12, graphicYOffset:-25 }
vectorLayer.addFeatures(feature);
map.addLayer(vectorLayer);
</script>
</body>
</html>
Thanks in advance for any tips.
Fab
http://twitter.com/extremoburo
http://www.linkedin.com/in/fburatta
http://www.nonfateviprenderedalpanico.it
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
