[OpenLayers-Users] Re: Modify feature
Tondo gpktondo at gmail.com
Tue Mar 20 16:25:45 EDT 2012
Update:
There is more... I found that I'm not able to select verticies of the
feature. If I try to drag some I drag map instead. Features can't be
selected via map, only by Attribute Table (also GeoExt/ExtJS stuff). I've
got "select style" assigned to vector layers, but when selected feature via
modifyFeature control, it seems to combine my select style (areas, lines,
points, verticies) with default OL style (not sure how to call it...
semi-vertex between two verticies). I'm confused...
Tom
View this message in context: http://osgeo-org.1560.n6.nabble.com/Modify-feature-tp4638011p4638219.html
