[OpenLayers-Users] Remove Layer not working
Steve Nelson
snelson at webapper.com
Mon Mar 26 11:30:21 EDT 2012
I'm running into this same problem. Did you find a solution to this?
Steve
On Tue, Feb 14, 2012 at 8:09 AM, GNR Revolution <dieconnex at hotmail.com>wrote:
> Hi there,
> I'm fairly new to Openlayers, and I am having a problem that I cannot
> figure
> out so hoping someone can enlighten me. Basically I have a button that I
> wish to use to add or remove a control (in this case a legend image) to the
> map. The adding works fine, but even though I hit the removecontrol
> element
> of the code nothing happens, can anyone explain why? Code snippet is
> below,
> called by the button trigger:
> function GetLegendState() {
> if (bLegendState == false)
> map.addControl (Legend);
> bLegendState = true;
> else if (bLegendState == true)
> map.removeControl (Legend);
> bLegendState = false;
> else
> The else if element is being reached (tested via alert) but the
> map.removeControl (Legend) doesn't seem to do anything?
> http://osgeo-org.1560.n6.nabble.com/Remove-Layer-not-working-tp4468764p4468764.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120326/2f46cedc/attachment.html
