[OpenLayers-Users] Re: Bug in select/unselect cluster feature and
zoom in and out?
jkm
rifins at gmail.com
Thu Mar 29 04:08:18 EDT 2012
Making a little research on that..
I've seen that there is a ticket that seems to be similar to my issue..
http://trac.osgeo.org/openlayers/ticket/1806
Could this be related?
Thanks!
El 28 de març de 2012 17:04, jkm <rifins at gmail.com> ha escrit:
> Hi,
> I would like to know if I'm doing something wrong, or not..
> I have a cluster strategy associated to a vector layer.. And I select and
> unselect features with the "selectCtrl":
> selectCtrl = new OpenLayers.Control.SelectFeature(layerTest, {
> onSelect: onFeatureSelect, onUnselect: onFeatureUnselect });
> map.addControl(selectCtrl);
> selectCtrl.activate();
> When I select a feature I do:
> function onFeatureSelect(feature) {
> selectedFeature = feature;
> if (currentPopup) currentPopup.hide();
> if (!feature.cluster) {
> if (!feature.popup) {
> popup = new OpenLayers.Popup.FramedCloud("chicken",
> feature.data.point, null, feature.data.info, null, true, onPopupClose);
> feature.popup = popup;
> else { popup = feature.popup; }
> else {
> var txt = 'Clustered feature';
> feature.cluster[0].data.point, null, txt, null, true, onPopupClose);
> map.addPopup(popup);
> currentPopup = popup;
> What I pretend is to show a popup indicating the information of a single
> point, or indicate that the point is a cluster of different features.
> When I unselect a feature, I do:
> function onFeatureUnselect(feature) {
> if (currentPopup) {
> if (currentPopup = feature.popup) {
> map.removePopup(feature.popup);
> feature.popup.destroy();
> feature.popup = null;
> currentPopup = undefined;
> If the feature has an associated popup, I destroy it.
> But, if I show a popup for a feature and I zoom in or out making feature
> changing (because there are more features clustered, or on the other side,
> the cluster doesn't exist anymore), when I unselect the feature, I get an
> error in Openlayers.js, in the unhighlight function:
> "layer.drawFeature(feature,feature.style||feature.layer.style||"default");"
> And this is due to the feature.layer is null...
> I don't know if i'm definig something in a bad way, or what is happening
> here.. Any help will be apreciated.
> Thanks!
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120329/b7a54a2a/attachment.html
