AW: [OpenLayers-Users] How can I display each polygon in a
differentcolor?
Markus Zielonka
zielonka.markus at yahoo.de
Fri May 4 04:41:48 EDT 2012
Thanks. I will test it.
Bye Markus
Von meinem iPad gesendet
Am 03.05.2012 um 22:10 schrieb "Arnd Wippermann" <arnd.wippermann at web.de>:
> It's the same as with your firestations layer:
> map.addLayer(new OpenLayers.Layer.GML("OV's 2.000 Meter", "2000meter.xml", {
> format: OpenLayers.Format.KML({extractStyles:false}),
> style: {strokeColor: "red", strokeWidth: 5, strokeOpacity: 1,
> fillColor:red, fillOpacity:0.5},
> projection: map.displayProjection
> Except you don't ectract the styles from the kmlfile.
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: openlayers-users-bounces at lists.osgeo.org
> [mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Markus
> Gesendet: Donnerstag, 3. Mai 2012 19:07
> An: openlayers-users at lists.osgeo.org
> Betreff: [OpenLayers-Users] How can I display each polygon in a
> differentcolor?
> Hello OpenLayers Team.
> i have this Code dev. (Attachment).
> How can I display each polygon in a different color?
> format: OpenLayers.Format.KML, projection:
> map.displayProjection }));
> map.addLayer(new OpenLayers.Layer.GML("OV's 4.000 Meter", "4000meter.xml", {
> First in Green
> Second in Red
> Search a good documentation and example. Found something but not help.
> Thanks all.
> Bye Markus
> My Map online: http://www.meldekopf.de/osm/pn/map.html
