[OpenLayers-Users] Re: To display pop up image when click point in
open layer web map
sacprasanna
sacprasanna at gmail.com
Fri May 4 10:01:15 EDT 2012
Hi all and Harshad,
Thanks for your answer,
I am still new to web development so It is very hard to understand
what you tell.If you can give me some example or sample code or some links
it is very help full for me.
Really Thanks for your quick reply
On Fri, May 4, 2012 at 5:40 PM, Harshad S [via OSGeo.org] <
ml-node+s1560n4952069h67 at n6.nabble.com> wrote:
> Hi ,
> A simple solution that I can think of is showing HTML text that
> contains the tags for the image as a popup using simple AJAX. You would be
> required to write a Javascript function that handles the click event for a
> point on the map. The xmlhttp response can come from your server-side
> scripting languages.
> I hope it helps.
> Thank You.
> Harshad Shrikhande
> -----[hidden email] <http://user/SendEmail.jtp?type=node&node=4952069&i=0>wrote: -----
> To: [hidden email] <http://user/SendEmail.jtp?type=node&node=4952069&i=1>
> From: sacprasanna
> Sent by: [hidden email]<http://user/SendEmail.jtp?type=node&node=4952069&i=2>
> Date: 05/04/2012 04:49PM
> Subject: [OpenLayers-Users] To display pop up image when click point in
> open layer web map
> Hi all,
> I have basic WMS web map showing parcels and points layer which representing
> buildings of parcel.Then I want to add building images for each and every
> point.And when user click that point image should apper as pop up window.
> I am using OpenLayers 2.10 Beginner's Guide book and can't find any method
> to above thing.
> Is this possible with open layers? IF so Pls give me some advise or some
> links to help me. [All layer are in WMS form and i am using geoserver and
> tomcat.]
> Thanks lot for your valuable time.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/To-display-pop-up-image-when-click-point-in-open-layer-web-map-tp4951964.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4952069&i=3>
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Notice: The information contained in this e-mail
> message and/or attachments to it may contain
> confidential or privileged information. If you are
> not the intended recipient, any dissemination, use,
> review, distribution, printing or copying of the
> information contained in this e-mail message
> and/or attachments to it are strictly prohibited. If
> you have received this communication in error,
> please notify us by reply e-mail or telephone and
> immediately and permanently delete the message
> and any attachments. Thank you
> Users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4952069&i=4>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/To-display-pop-up-image-when-click-point-in-open-layer-web-map-tp4951964p4952069.html
> To unsubscribe from To display pop up image when click point in open
> layer web map, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4951964&code=c2FjcHJhc2FubmFAZ21haWwuY29tfDQ5NTE5NjR8LTIwMzA3MDM5NjY=>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/To-display-pop-up-image-when-click-point-in-open-layer-web-map-tp4951964p4952303.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120504/6cbc8a71/attachment-0001.html
