[OpenLayers-Users] offset polygon
Steve Nelson
snelson at webapper.com
Fri May 4 16:32:55 EDT 2012
I found it. It works like a charm. Thanks Stephen!
Steve
On Fri, May 4, 2012 at 3:48 PM, Steve Nelson <snelson at webapper.com> wrote:
> I see what you mean. For this project, true offset isn't important.
> Resizing is perfect. Is there a built in function for resizing?
> Steve
> On Fri, May 4, 2012 at 2:10 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> On 5/4/2012 11:26 AM, Steve Nelson wrote:
>>> Does anyone have a function that can create an offset polygon?
>>> In other words, if I have a polygon made up of 5 points have the same
>>> polygon shape, just a larger size?
>> Hi Steve,
>> These are not the same thing.
>> If you want the same shape only larger then you are looking a scale.
>> If you want and offset, this is MUCH more complicated because you have to
>> deal with changes in topology, like if you have a small V shape then you
>> offset might cause these to be removed like:
>> ----------------- offset
>> ------\ /------- curve
>> or if your polygon has a hole then an offset could result in a smaller
>> hole or with the hole getting filled in and removed. There are many cases
>> like this. These are just a couple of examples to give you the idea.
>> So what DO you need? Resizing via scale is easy, True offset is hard!
>> -Steve W
>> ______________________________**_________________
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120504/8b8be9eb/attachment-0001.html
