[OpenLayers-Users] How to completely erase a map?
Eric Lemoine
eric.lemoine at camptocamp.com
Sat May 5 03:12:48 EDT 2012
On Saturday, May 5, 2012, alexe100 wrote:
> Hi
> I have a map which embedds :
> var layer = new OpenLayers.Layer.OSM(...
> var vectorLayer = new OpenLayers.Layer.Vector(...
> var renderer =
> OpenLayers.Util.getParameters(window.location.href).renderer;
> and
> var selectControl = new OpenLayers.Control.SelectFeature(...
> It shows very well including vectors and tooltips.
> On the html page i have a check box called Automatic Refresh. If i check
> this control a timer is set with a period of 5 secods.
> For each 5 seconds the page requests new (current) GPS positions from the
> servlet for the vehicles.
> When those positions arrive I clear the structure vector and store the new
> positions and then I need to update the positions on the map. To simplify
> the operation I do this:
> for (var i = map.layers.length - 1; i >= 0; i--)
> map.removeLayer(map.layers[i]);
> and then I call Init() again to create the (new) map
> but the map does not show very well. It seems that part of the old map
> remains on the bottom of the screen/div and the new map is drawn above it.
> Is this the right way to do the map update?
Use map.destroy() to destroy a map entirely.
> Can I simple update only the layer on the vehicles positions icons? if so,
> what about the already stablished SelectFeatures for that layer? Do I have
> to delete them too? how?
You can do vectorLayer.destroyFeatures() to empty the layer and then add
the new poditions.
Also, you may want to look at the Refresh strategy.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120505/0a6deb25/attachment.html
