AW: [OpenLayers-Users] Circle around clicked point
Arnd Wippermann arnd.wippermann at web.de
Thu May 10 10:13:23 PDT 2012
First argument of createRegularPolygon is the origin like
var origin = {x:lonlat.lon, y:lonlat.lat};
var circleout = new OpenLayers.Geometry.Polygon.createRegularPolygon(origin,
0.0096, 50);
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Alberto
Najera
Gesendet: Donnerstag, 10. Mai 2012 18:09
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] Circle around clicked point
Hello
I need to draw a circle around a click selected point on the map. Looking at
samples in this forum, some web search as well as the OpenLayers page, I
have put the  following code together, but the circle is not drawn. The map
is in EPSG 4326 so units are decimal degrees.
I added a vector layer where the circle shall be drawn:
   var vector_layer = new OpenLayers.Layer.Vector("Zona Influencia")
    //Add layers to the map
    map.addLayers([layer1, layer2, vector_layer]);
//Register the click event to get the clicked point coordinates
    map.events.register('click', map, Circulo);
   var map_center = new OpenLayers.LonLat(-99.24801,19.49775);
	 if(!map.getCenter()){
			map.setCenter(map_center);
// Function to draw the circle around the clicked point
function Circulo(evt)
       var lonlat = map.getLonLatFromViewPortPx(evt.xy);
       // use lonlat
	var circleout = new
OpenLayers.Geometry.Polygon.createRegularPolygon(lonlat, 0.0096, 50);
	vector_layer.addFeatures(new OpenLayers.Feature.Vector(circleout));
What am I missing?
Full page code is as follows:
<!DOCTYPE html>
<html lang='en'>
<head>
    <meta charset='utf-8' />
	<title>Open Layers Test</title>
    <script type='text/javascript'
src="http://www.openlayers.org/api/OpenLayers.js"></script>
    <script type='text/javascript'>
    var map;
	function init() {
        // Setup our map object
        map = new OpenLayers.Map('map_element', {
        	controls: [
        	new OpenLayers.Control.Navigation(),
        	new OpenLayers.Control.PanZoomBar(),
        	new OpenLayers.Control.LayerSwitcher(),
        	new OpenLayers.Control.ScaleLine()
        	maxExtent: new OpenLayers.Bounds (-99.269569,19.479910,
-99.224060, 19.524080),
        	maxScale: 15000,
        	minScale: 2500
       // Setup our layer objects
   var layer1 = new OpenLayers.Layer.WMS(
		"Parques",
		"http://myhost/cgi-bin/mapserv?",
		{map: '/home/bicimapas/mapdata/BiciMapasMS.map',
	layers:'parque'});
   var layer2 = new OpenLayers.Layer.WMS(
		"Caminos",
		layers:'caminos', transparent: true}, {isBaseLayer:false});
// Vector layer to draw the circle
       // use lonlat
	var circleout = new
    </script>
</head>
<body	onload='init();'> mapa de prueba
    <div id='map_element' style='width: 700px; height: 500px; border: 1px
solid black'>
	</div>
</body>
</html>
Thanks in advance for your help
Alberto Najera
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
