[OpenLayers-Users] Layer.OSM / Layer.XYZ: show only a subset of
all available resolutions
Franz Buchinger
fbuchinger at gmail.com
Fri May 11 03:03:30 PDT 2012
I'm currently fighting with the same problem... is there already an easier
way to accomplish this?
I was playing around a while with minZoomLevel/maxZoomLevel but couldn't
get Openlayers to display just the OSM zoomlevels 11 - 18.
Nevertheless thanks a lot for this valuable hint,
Franz
2012/1/24 Marc Jansen <jansen at terrestris.de>
> Hi Andreas,
> helpfull as always! This is indeed a very cool addition to OpenLayers. I
> will see if the application in question can move to git-master.
> Thanks a lot and kind regards,
> Marc
> On 24.01.2012 15:20, Andreas Hocevar wrote:
>> Not with the 2.11 release, but with current master (this was fixed
>> shortly after the release):
>> new OpenLayers.Map({
>> div: "map",
>> layers: [new OpenLayers.Layer.OSM(null, null, {
>> resolutions: [76.43702827148438, 19.109257067871095],
>> serverResolutions: [156543.03390625, 78271.516953125,
>> 39135.7584765625, 19567.87923828125, 9783.939619140625,
>> 4891.9698095703125, 2445.9849047851562,
>> 1222.9924523925781,
>> 611.4962261962891, 305.74811309814453, 152.87405654907226,
>> 76.43702827453613, 38.218514137268066, 19.109257068634033,
>> 9.554628534317017, 4.777314267158508, 2.388657133579254,
>> 1.194328566789627, 0.5971642833948135,
>> 0.29858214169740677,
>> 0.14929107084870338, 0.07464553542435169]
>> center: new OpenLayers.LonLat(16.37, 48.21).transform(
>> new OpenLayers.Projection("EPSG:**4326"),
>> new OpenLayers.Projection("EPSG:**900913")
>> Andreas.
>> On Tue, Jan 24, 2012 at 2:31 PM, Marc Jansen<jansen at terrestris.de>
>> wrote:
>>> Hi list,
>>> I currently fail at implementing the following:
>>> Build a map that has a OpenLayers.Layer.OSM-layer, but which will only
>>> display some of the possible zoomlevels, e.g. only the zoomlevel 11
>>> (resolution = 76.43702827148438) and the zoomlevel 13 (resolution =
>>> 19.109257067871095).
>>> This sounds easy at first... but yet I am struggling with this. I tried
>>> numerous combinations of resolutions, serverResolutions and zoomOffset
>>> but
>>> without success. Is this doable with current 2.11-API?
>>> Thanks for any help on this.
>>> Best regards,
>>> Marc
>>> ______________________________**_________________
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120511/cc93d0f2/attachment-0001.html
