AW: [OpenLayers-Users] World user map
Arnd Wippermann
arnd.wippermann at web.de
Wed May 16 16:37:36 PDT 2012
it seem to be an issue with conference.css
try
.section img {
/* padding-top: 5; */
padding-top: 0;
Arnd
_____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Paul Meems
(Top-X)
Gesendet: Mittwoch, 16. Mai 2012 18:53
An: openlayers-users
Betreff: Re: [OpenLayers-Users] World user map
Thanks to the suggestion made by Barend Köbben I found this post
http://thematicmapping.org/playground/openlayers_propsymbols_geojson.php
which was showing what I need.
I've altered the example and it is now running at
http://www.mapwindow.org/conference/2012/usermap.html
But when I put the code (not that much) in the webpage with the participants
I get horizontal transparent 'lines' in my OSM base map.
Because my div has a gray background the lines are gray as well.
This is probably some CSS issue, but I haven't figured it out.
http://www.mapwindow.org/conference/2012/participants.php
Thanks all for your help and if you have a suggestion of the fix the lines
let me know.
Paul
Project manager Open Source GIS Conference 2012
2012/5/15 Barend Köbben <kobben at itc.nl>
Hi Paul,
For such a relatively simple map I would probably not even use a WxS, just
a geojson file of a simple world map and javascript to read the attributes
of how many visitors per country. You could probably use OpenLayers for
that (which I did not try myself), but other solutions too, see e.g the
example of a simple thematic maps made with the D3 library at
http://kartoweb.itc.nl/kobben/test/buurten.html
BTW, you should of course not use a map where you color countries if a
person comes from there (a so-called choropleth or chorochromatic map).
That would greatly misdirect the user into thinking many people come from
e.g. Russia, because he sees a huge red polygon, while none seem to come
from Luxemburg (which he won't see at al at that scale). In reality maybe
20 are from Luxemburg and only 1 from Russia. Better use proportional
point symbols per country, see ge, the map "AANT_INW" in the example
mentioned above...
Barend
Barend Köbben
Senior Lecturer, ITC - University of Twente,
Faculty of Geo-Information Science and Earth Observation
PO Box 217, 7500AE Enschede (The Netherlands)
+31-(0)53 4874 <tel:%2B31-%280%2953%204874%20253> 253
On 14-05-12 22:34, "Paul Meems" <bontepaarden at gmail.com> wrote:
>Hi,
>I'm working on a kind of user map.
>It should be a map with all the countries of the world and the countries
>are colored if someone from that country is coming to the Open Source GIS
>conference.
>I also need a label with the name of the country and the number of people.
>I have some experience with OL together with GeoServer and PostGIS, but
>for this web page I can't use that.
>I think I need a WFS server that has the countries of the world and then
>use a GML file with my data to create the labels and color the countries,
>am I right?
>I'm already stuck at the first step. Is a public WFS server available
>that I can use to do this?
>I've already made a static image of what I want, but I would rather use
>OL.
>Can anybody advise me on this?
>Here are my static images:
><http://www.mapwindow.org/conference/2012/participants.php>
>Thanks,
>Paul
Faculty of Geo-Information Science and Earth Observation (ITC)
Chamber of Commerce: 501305360000
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for
the addressee only. If you are not the intended recipient, you are hereby
notified that any disclosure, copying, distribution or action in relation to
the content of this information is strictly prohibited. If you have received
this e-mail by mistake, please delete the message and any attachment and
inform the sender by return e-mail. ITC accepts no liability for any error
or omission in the message content or for damage of any kind that may arise
as a result of e-mail transmission.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120517/c33dab57/attachment-0001.html
