[OpenLayers-Users] Re: no intersection when features snap
Peter
pfischer at proveo.com
Fri May 18 02:24:33 PDT 2012
so first of all thanks for your reply.
var intersectableFeatures = priorityLayerArray[i].features;
//each features
for (var j = 0; j < intersectableFeatures.length; j++)
//current feature to comapre
var currentfeature = intersectableFeatures[j];
//Compare with others
for (var x = 0; x < intersectableFeatures.length; x++)
//compared fieature
var comparefeature = intersectableFeatures[x];
//check if not same feature
if(currentfeature.attributes.name === comparefeature.attributes.name)
continue;
else
var isIntersecting =
currentfeature.geometry.intersects(comparefeature.geometry,{touching:false});
if(isIntersecting)
alert(currentfeature.attributes.name + " intersects with: " +
comparefeature.attributes.name);
This is my Code where i try to check the intersection. the
priorityLayerArray[] is an array where i save different layers, so the
priorityLayerArray[i] is the layer i want to check if it has some features
wich intersects.
So is there no way in openlayers itself to check if the features overlap or
only touches?
greetings
View this message in context: http://osgeo-org.1560.n6.nabble.com/no-intersection-when-features-snap-tp4967965p4975550.html
