[OpenLayers-Users] Tooltip for vectorlayer icons
Matthias Meißer
digi_c at arcor.de
Sun May 20 02:55:55 PDT 2012
Am 19.05.2012 19:09, schrieb Andreas Hocevar:
> If you download the latest OpenLayers (master from
> http://github.com/openlayers/openlayers, you can simply give your
> symbolizer a 'graphic' property. If your feature attributes have e.g. a
> 'tooltip' attribute, the value for the 'graphic' property would be
> '${tooltip}'.
> See http://openlayers.org/dev/examples/vector-features.html for an example.
Thanks Andreas, that worked fine for me! But the property is
title:'blablub' ;)
Unfortunately the newest release seems to make troubles with popups.
Matthias
> On May 19, 2012 6:59 PM, "Matthias Meißer" <digi_c at arcor.de
> <mailto:digi_c at arcor.de>> wrote:
> Hi,
> I'm working on a map, that get's geoJSON data for a vector layer
> using an simple REST API server. As I only display the labels on
> demand and a the density of vector points can get quiet high, I like
> to display a usual native tooltiptext (aka hint). So if the
> mousepointer get's over an item, a small text appears that displays
> a custom text.
> Unfortunately it doesn't seem so easy to realise? I found a lot of
> old code snippets, that implement it by hand using hover event
> listeners. On the other side there is www.openflights.org
> <http://www.openflights.org> that has exactly this behaviour, but
> the GraphicTitle sollution seems to be limited to icon based
> visualisiations, right?
> So how can I get the same functionality, without coding from scratch?
> bye
> Matthias
> _________________________________________________
> Users mailing list
> Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/openlayers-__users
> <http://lists.osgeo.org/mailman/listinfo/openlayers-users>
