[OpenLayers-Users] Openlayers.map with no div. Javascript on server side
Robert Sanson
Robert.Sanson at asurequality.com
Mon May 28 18:31:26 PDT 2012
It would be better to use something like JTS as a Java servlet, or Shapely as Python code inside a cgi-bin script
>>> alexe100 <imoveisnacionais at gmail.com> 29/05/2012 11:58 a.m. >>>
Hi
Is it possible to instantiate a openlayers.map object with no div?
I am asking this question because of this:
I have javascript file that constructs a openlayers.map with a function that
tells me if a point is inside a polygon or not. All works good.
But i need that functionality (point is inside/outside a polygon) on server
side, in a servlet.
As far as i know, it is possible to run a javascript file on servlet. Now I
am trying to execute the script file inside the servlet and ask the script
if a point is inside or outside a polygon but I am having troubles in de
first javascript instruction which is Openlayers.map(div). Now there is no
div and i dont need it either.
How to build a map without providing a div object?
Thanks a lot
Alex
View this message in context: http://osgeo-org.1560.n6.nabble.com/Openlayers-map-with-no-div-Javascript-on-server-side-tp4977562.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
