[OpenLayers-Users] Possible in openlayers?
Gery .
gamejihou at hotmail.com
Tue May 29 02:12:37 PDT 2012
Hello Gary,
I think it is possible, draw features is provided by Openlayers, check the examples web: http://openlayers.org/dev/examples/
If you want to add info, if I'm right, you just need to implement it in Openlayers, I think it is possible but not sure how. Now, if you use MapFish certainly you will be able to do this, check here: http://demo.mapfish.org/mapfishsample/2.2/ this demo is quite amazing, I'm still struggling to install it and run it but if in this link it works, it should work in my pc =)
Hope this helps,
Gery
To: openlayers-users at lists.osgeo.org
Date: Tue, 29 May 2012 09:45:43 +0100
Subject: [OpenLayers-Users] Possible in openlayers?
I am new to web based mapping and I am looking at developing a map that allows users to draw features (line, polygon and point). However I wish user to be able to add information in a text format to each vector such as ‘name’ and ‘description’ and then be able to download each vector type in kml format or shp. Is this currently possible with OpenLayers. Any advice would be greatly appreciated. Gary
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120529/3b3d9f62/attachment.html>
