[OpenLayers-Users] Map displays partially on Internet Explorer 7
Xavier Mamano (jorix) xavier.mamano at gmail.com
Sun Nov 4 14:31:57 PST 2012
Using compatibility mode on IE9 also fails. You tried to control the height
on `#main-map` by javaScript instead of using a percentage as `#main-map
{... height: 93%; ...}`? So not wasted any height pixel of the map.
Note: I use javascript to control the height (I use also an upper band in my
full screen map with TileCache (similar to OSM) and an upper band), and
behaves correctly using IE9 compatibility mode.
Étienne Loks wrote
> Hi,
> A thematic map displayed with Openlayers works well on any major
> browser but it displays only partially on Internet Explorer 7 (half bottom
> of
> the map doesn't display).
> An example is available here: http://chimere.proxience.com
> This must be relative to a CSS applied to the page but I can't find what
> is
> causing this behavior.
> Have you got any clue?
> Thanks.
> Étienne Loks
> Users mailing list
> Users at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
View this message in context: http://osgeo-org.1560.n6.nabble.com/Map-displays-partially-on-Internet-Explorer-7-tp5011978p5013887.html
