[OpenLayers-Users] FW: tilecache
Gery .
gamejihou at hotmail.com
Tue Nov 6 03:02:17 PST 2012
thanks, I've been testing things in my MAP file about projections and after playing with the resolution bar of the openlayers I noticed that the layer displays correctly in all the 20 resolution levels I have, except in the 611.4962261962891, it's really strange, any ideas?
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
> To: openlayers-users at lists.osgeo.org
> From: mario.danelli at gmail.com
> Date: Mon, 5 Nov 2012 13:47:28 +0000
> Subject: Re: [OpenLayers-Users] FW: tilecache
> Gery . <gamejihou at ...> writes:
> > Now after zooming into the map (whatever area), I got the image,
> so tilecache is
> working properly, but I get this in the apache error log:
> [Mon Nov 05 12:35:46 2012] [error] Cache miss:
> -8805545.66046,-1526294.58411,-8766409.90199,-1487158.82564,
> Tile: x: 287, y: 473, z: 10, time: 0.0658960342407If
> >[Mon Nov 05 11:55:05 2012] [error]
> Cache hit: -9079495.96979,-1721973.37649,-8922952.93589,-1565430.34259,
> Tile: x: 70, y: 117, z: 8, time: 0.000137090682983, debug: True
> The "cache hit" entry it's only and advice (debug: True).
> It means that the program found the request tile into the "cache" folder
> (it's a physical folder into the application root folder).
> The "cache miss" is the same. It means that the program DOESN'T found
> the request tile into the "cache" folder so the application create
> the tile and put it into the "cache" folder for a future request
> for the same tile.
> Mario Danelli
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121106/820a9357/attachment.html>
