[OpenLayers-Users] OpenLayers.Feature.Vector to json
Gabriel Vatin gabriel.vatin at mines-paristech.fr
Wed Nov 14 08:17:01 PST 2012
I think you can use the function JSON.stringify() from json2.js library
that converts a JavaScript array to JSON :
https://github.com/douglascrockford/JSON-js
I've never tried it, I just found it, but I would be interested to know
if it's ok ! :)
So you get your feature(s) with OpenLayers.Feature.Vector.features[] and
pass it to the stringify funtion, that should work fine !
Gabriel
On 14/11/2012 16:26, islanis at infomed.sld.cu wrote:
> Hi people, exist the posibility of convert the data or attributes
> fields of "OpenLayers.Feature.Vector" to "json" cause i need it to
> work and i dont know a way to solve that, or retrieve the columns or
> fields value of the data or attributes fields, for example these is
> what i get with firebug
> Object { cpopular="xcvx", empresa="vxcvxc",
> nombre="cvxcv",cantidad="xcvxcv",func="xcvxcv",ubicacion= "xcvxcv"}
> cantidad "xcvxcv"
> cpopular "xcvx"
> empresa "vxcvxc"
> func "xcvxcv"
> nombre "cvxcv"
> ubicacion "xcvxcv"
> i need to convert it to json i means to this:
>  { "cpopular":"xcvx", "empresa":"vxcvxc",
> "nombre":"cvxcv","cantidad":"xcvxcv","func":"xcvxcv","ubicacion":
> "xcvxcv"}
> or get the fields in form of array to convert my self to json cause i
> cant get the column values i mean:
> [cantidad,
> cpopular,
> empresa,
> func,
> nombre,
> ubicacion]
> thanks to all you
> This message was sent using IMP, the Internet Messaging Program.
> Este mensaje le ha llegado mediante el servicio de correo electronico
> que ofrece Infomed para respaldar el cumplimiento de las misiones del
> Sistema Nacional de Salud. La persona que envia este correo asume el
> compromiso de usar el servicio a tales fines y cumplir con las
> regulaciones establecidas
> Infomed: http://www.sld.cu/
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
