[OpenLayers-Users] highcharts server side to generate png not working
islanis at infomed.sld.cu
Fri Nov 16 16:32:38 PST 2012
Hi people i have problems, use the index.php that comes inside the
"\Highcharts-2.3.3\exporting-server\php" and simply it does not work,
i put a i did this inside the index.php
define ('BATIK_PATH', 'batik-1.7/batik-rasterizer.jar');
ini_set('magic_quotes_gpc', 'off');
$type = $_POST['type'];
$svg = (string) $_POST['svg'];
$filename = (string) $_POST['filename'];
die($type.$svg.$filename."respuesta");
and it shows "respuesta" alone.
and without die() it show "Invalid type".
and my code of chart is this
var chart1;
var cont;
var div = document.createElement('div');
chart1 = new Highcharts.Chart({
chart:{
//animation: !1,
//reflow: !1,
//zoomType: "x",
renderTo: div,
type: 'bar'/*,
marginBottom: 0,
marginLeft: 0,
marginRight: 0,
marginTop: 0,*/
//marginTop: 10
title:{
text: ''
xAxis:{
categories: ['Enero', 'Febrero',
'Marzo','Abril','Mayo','Junio','Julio','Agosto','Septiembre','Octubre','Noviembre','Diciembre'],
labels:{
style:{
fontSize: '16px',
fontFamily: 'Helvetica Neue,Helvetica,Arial,sans-serif',
color: 'black'
title: {
text: 'Mes'
plotOptions: {
series: {
borderWidth: 1,
/*stacking: 'normal,',
pointWidth: 28,*/
pointHeigh: 32,
stroke :"green",
strokeWidth:2,
color: color
yAxis:{
title:{
text: 'KWh/m2;',
style:{
fontSize: '14px',
color: 'black',
fontWeight: 'normal'
labels: {
rotation: -45,
style: {
font: 'normal 9px Verdana, sans-serif, arial'
tooltip:{
formatter: function() {
return ''+'en '+ this.x +': '+ redondeo(this.y) +" KWh/m2";
legend: {
layout: 'vertical',
align: 'left',
verticalAlign: 'bottom',
x: 0,
y: 0,
floating: true,
borderWidth: 1,
backgroundColor: '#FFFFFF',
shadow: true
series: [{
borderWidth: 0.1,
data:data,
shadow: true,
dataLabels: {
enabled: true
exporting:{
url:"http://10.8.194.221/personal/assets/ge/bin"
help please, i need this option to my thesis project.
thanks to all
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
