[OpenLayers-Users] Display Coordinates
Riggi Valerio vash.84 at virgilio.it
Thu Nov 22 02:15:29 PST 2012
I corrected the code but still I don't understand a thing.. when I go on
the WGS-84 map (http://www.intornoamessina.it/tracking/) and I point the
mouse at a certain point of coordinate -93.2735, 44.8349 the result is
like 4613718.1118, 1718560.9374, should not be like the coordinates before?
Many Thanks
Valerio
Il 21/11/2012 20:16, Arnd Wippermann ha scritto:
> OpenLayers.Util.getFormattedLonLat(lat)is for formating geographic
> coordinates,
> but you pass projected coordinates to the function. That's the reason
> for the strange output.
> Util.js:
> OpenLayers.Util.getFormattedLonLat = function(coordinate, axis,
> dmsOption) {
>     if (!dmsOption) {
>         dmsOption = 'dms';    //default to show degree, minutes, seconds
>  coordinate = (coordinate+540)%360 - 180; // normalize for sphere
> being round
> Choose displayProjection: geographic and if you want to output your
> mousemove coordinates also in the projected coordinates,
> you have to transform them.
>             formatOutput: function(lonLat) {
>                 var geoCoor = lonLat.clone().transform(geographic,
> mercator);
>                 var lat = lonLat.lat;
> see:
> http://gis.ibbeck.de/ginfo/apps/OLExamples/OL212/PointTrack_Boaga_Projection.asp
> Regard,
> Arnd
> *Von:* openlayers-users-bounces at lists.osgeo.org
> [mailto:openlayers-users-bounces at lists.osgeo.org] *Im Auftrag von
> *Riggi Valerio
> *Gesendet:* Mittwoch, 21. November 2012 11:30
> *An:* openlayers-users at lists.osgeo.org
> *Betreff:* Re: [OpenLayers-Users] Display Coordinates
> Cit.:
> Set the displayProjection property when you create the map to the
> projection (not the projection code) that you want the coordinates to
> be in.  (looks like it should be a projection created from EPSG:4326)
> The lat/lon being passed into the mousecontrol event will be in this
> projection. It look to me like you are getting in projected
> coordinates but trying to use them as lat/long.
> Done but the problem remains.
> Il 20/11/2012 15:28, Riggi Valerio ha scritto:
>> Hi, I'm tryng to display the coordinates on mouse over the map, on a
>> WGS84 map and on a Gauss-Boaga map but coordinate seems strange to
>> me, is there some error? I'm using the example bellow:
>> This is the WGS84 map
>> <http://www.intornoamessina.it/tracking/index.php> and this is the
>> Gauss-Boaga Map <http://www.intornoamessina.it/tracking/index.php?gauss>
>> And this is the *example code* I used:
>>     map.addControl(
>>                 new OpenLayers.Control.MousePosition({
>>                     prefix: '<div style=\"color: green; font-size:
>> 14px; font-weight: bold; background-color: white; width: 500px;
>> text-align: left;\">Coordinate: ',
>>                     suffix: '</div>',
>>                     separator: ' | ',
>>                     numDigits: 2,
>>                     emptyString: '<div style=\"color: red; font-size:
>> text-align: left;\">Mouse non sulla mappa.</div>'
>>     map.events.register("mousemove", map, function(e) {
>>                 var position = this.events.getMousePosition(e);
>>                 OpenLayers.Util.getElement("coords").innerHTML =
>> position;
>>     map.addControl(new OpenLayers.Control.Attribution());
>> *Thanks**
>> **Valerio*
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121122/b9230695/attachment-0001.html>
