[OpenLayers-Users] Display Coordinates
Arnd Wippermann
arnd.wippermann at web.de
Fri Nov 23 13:36:09 PST 2012
you have to set your variable mercator to the right projection.
from kml-pointtrack.js.php:
var mercator = new OpenLayers.Projection("EPSG:4326"); <!-- WGS84 -->
var geographic = new OpenLayers.Projection("EPSG:4326"); <!-- WGS84 -->
it should be
var mercator = new OpenLayers.Projection("EPSG:900913");
Arnd
_____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Riggi
Valerio
Gesendet: Freitag, 23. November 2012 15:32
An: openlayers-users at lists.osgeo.org
Betreff: Re: [OpenLayers-Users] Display Coordinates
I was missing an "else if" on my code and the mercator was always setted to
EPSG:900913, now it seems to work but the wgs-84 version dosen't center the
map on the desired position:
center: new OpenLayers.LonLat(15.4386126995087,
38.2423138618469).transform(geographic, mercator)
why?
Many thanks
Valerio
Il 22/11/2012 22:08, Phil Scadden ha scritto:
Okay, you have added displayProjection.
So looking at the formatOutput function, I see.
lonLat now comes into the function as lat/lon in 4326.
you convert to mercator
However lonLat.transform changes lonLat.
try
var geoCoor = lonLat.clone();
geoCoor.transform(geographic, mercator);
var lat = lonLat.lat;
var long = lonLat.lon;
var ns = OpenLayers.Util.getFormattedLonLat(lat);
var ew = OpenLayers.Util.getFormattedLonLat(long,'lon');
return '<div style=\"color: green; font-size: 14px; font-weight: bold;
background-color: white; width: 700px; text-align: left;\">Coordinate: '
+ ns + ', ' + ew + ' (' + (Math.round(geoCoor.lat * 10000) / 10000) + ',
' + (Math.round(geoCoor.lon * 10000) / 10000) + ')' + '</div>';
Get used to using firebug or similar. It makes it easy to see what is
going on. Put breakpoint in formatOutput and then watch the values.
Notice: This email and any attachments are confidential. If received in
error please destroy and immediately notify us. Do not copy or disclose the
contents.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121123/a09dec1c/attachment.html>
