[OpenLayers-Users] Using external/inline SVG for a map feature
Bart van den Eijnden
bartvde at opengeo.org
Tue Nov 27 07:53:45 PST 2012
Did you look into:
http://trac.osgeo.org/openlayers/wiki/Addins/InlineXhtml
already?
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Nov 27, 2012, at 9:26 AM, Matt Wintercorn <matt at stackframe.com> wrote:
> Is it possible to use an external SVG definition as the source for a feature graphic in OpenLayers. My SVG already has the necessary <g> tags with all of the <path> elements containing my graphic. The only thing that I am seeing is that OpenLayers really only supports drawing points, lines, rectangles, and simple polygons by taking a list of points and "generating" an SVG. What can I do if I just want to use my existing SVG definition??? (I am using the SVG renderer and would like to take advantage of the built in SVG transforms to correctly scale and position my SVG element on the map)
> Matt Wintercorn
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121127/58d0692f/attachment.html>
