[OpenLayers-Users] registering a click event on a map
Richard Greenwood
richard.greenwood at gmail.com
Tue Sep 11 18:12:11 PDT 2012
On Tue, Sep 11, 2012 at 6:20 PM, Puneet Kishor <punk.kish at gmail.com> wrote:
> On Sep 10, 2012, at 7:16 PM, Richard Greenwood <richard.greenwood at gmail.com> wrote:
>> On Mon, Sep 10, 2012 at 1:38 PM, Puneet Kishor <punk.kish at gmail.com> wrote:
>>> In OL 2.11 I used to do the following successfully
>>> map.events.register(
>>> "click",
>>> map,
>>> function(e) {
>>> fancyFunction({evt: e, other_params: "foo"});
>>> The above has stopped working in Firefox (currently using FF v. 15.0.1) without any errors. It does work in Safari 6, but gives the following warning in the console.log
>>>> event.layerX and event.layerY are broken and deprecated in WebKit. They will be removed from the engine in the near future.
>>> Suggestions to fix both problems would be welcomed with thanks.
>> I believe the correct way to register a click handler is something like:
>> var click = new OpenLayers.Control.Click( {
>> trigger: function(e) {
>> /* do stuff */
>> map.addControl(click);
>> click.activate();
> Perhaps. But, when I use the above code, I get the following error
> TypeError: OpenLayers.Control.Click is not a constructor
Sorry, I did the same thing the last time I tried to answer this
question. You need to first create a new class:
// based on:
// http://dev.openlayers.org/docs/files/OpenLayers/Handler/Click-js.html
OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, {
defaultHandlerOptions: {
'single': true,
'double': false,
'pixelTolerance': 0,
'stopSingle': false,
'stopDouble': false
initialize: function(options) {
this.handlerOptions = OpenLayers.Util.extend(
{}, this.defaultHandlerOptions
OpenLayers.Control.prototype.initialize.apply(
this, arguments
this.handler = new OpenLayers.Handler.Click(
this, {
'click': this.trigger
}, this.handlerOptions
Based on my foggy recollection of previous threads I still believe
that the above is the preferred method rather than
map.events.register("click", ...)
I realize that register("click") exists in examples, but some of them
are pretty dated. Have a look at:
Rich
Richard Greenwood
www.greenwoodmap.com
