[OpenLayers-Users] Adding new Points of Interest before the map div
Marco Baumgärtner
kalleernst at googlemail.com
Wed Sep 12 11:42:14 PDT 2012
Hello.
I am using openlayers with osm.
I want to add new POIs to my map by using.
> var feature = new OpenLayers.Feature.Vector(
> new
> OpenLayers.Geometry.Point(1.234,1.234).transform(epsg4326, projectTo),
> {description:'desc'} ,
> {externalGraphic: 'image.png', graphicHeight: 10,
> graphicWidth: 10, graphicXOffset:-5, graphicYOffset:-5 }
> vectorLayer.addFeatures(feature);
Problem is, I want to do this in code before the map is being
initialized (in my code by)
> <div style="width:100%; height:100%;" id="mapdiv">
> </div>
> <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
> <script>
> OpenLayers.Lang.setCode('de');
> //map = new OpenLayers.Map("mapdiv", { controls: [] });
> map = new OpenLayers.Map("mapdiv", {controls: [new
> OpenLayers.Control.Attribution()]});
> map.addLayer(new OpenLayers.Layer.OSM());
> projectTo = map.getProjectionObject();
> epsg4326 = new OpenLayers.Projection("EPSG:4326")
> var lonLat = new OpenLayers.LonLat( 6.959911 , 50.940664
> ).transform(epsg4326, projectTo);
> var zoom = 14 ;
> map.setCenter(lonLat, zoom);
> var vectorLayer = new OpenLayers.Layer.Vector("Overlay");
> new OpenLayers.Geometry.Point( 6.959911 , 50.940664
> description: 'Standort'
> externalGraphic: 'schild.png',
> graphicHeight: 74 , graphicWidth: 53 , graphicXOffset: -26.5 ,
> graphicYOffset: -74
> map.addLayer(vectorLayer);
> //Add a selector control to the vectorLayer with popup functions
> var controls = {
> selector: new OpenLayers.Control.SelectFeature(vectorLayer,
> onSelect: createPopup,
> onUnselect: destroyPopup
> function createPopup(feature)
> feature.popup = new OpenLayers.Popup.FramedCloud("pop",
> feature.geometry.getBounds().getCenterLonLat(),
> null, '<div class="markerContent">' +
> feature.attributes.description + '</div>',
> null,
> true,
> function ()
> controls['selector'].unselectAll();
> //feature.popup.closeOnMove = true;
> map.addPopup(feature.popup);
> function destroyPopup(feature)
> feature.popup.destroy();
> feature.popup = null;
> map.addControl(controls['selector']);
> controls['selector'].activate();
> controls = map.getControlsByClass('OpenLayers.Control.Navigation');
> for(var I = 0; i < controls.length; ++i)
> controls.disableZoomWheel();
> </script>
If I put the javascript on top of the page and let the map div come
after, it does not show.
So basically I want to add new points somewhere in code before the map
div. How do I need to structure the javascript-parts to do that?
Best and thanks for your efforts.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120912/f0922b12/attachment.html>
