[OpenLayers-Users] (no subject)
Erdal Karaca
erdal.karaca.de at gmail.com
Fri Sep 14 05:25:47 PDT 2012
I just downloaded OpenLayers 2.12.
When loading my html page that includes a link elemente, I will get this
error message in Chrome:
Object [object HTMLLinkElement],[object HTMLLinkElement] has no method
'item'
It seems the following code is erronous (OpenLayers.debug.js:8070):
// only append link stylesheet if the theme property is set
if(this.theme) {
// check existing links for equivalent url
var addNode = true;
var nodes = document.getElementsByTagName('link');
for(var i=0, len=nodes.length; i<len; ++i) {
if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,
Uncaught TypeError: Object [object HTMLLinkElement],[object
HTMLLinkElement] has no method 'item'
this.theme)) {
Nodes is an array and has no method item(). Shouldn't it be nodes[i]
instead of nodes.item(i)?
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120914/85f9e272/attachment-0001.html>
