[OpenLayers-Users] moveend Openlayers v2.12
Brad Spencer brad at numaps.com.au
Tue Sep 18 00:22:53 PDT 2012
Eric,
Ok thanks for that. When I upgraded to v2.12 my map panning was broken. I
was using OpenLayers.Control.MouseDefaults and the doco said it was
deprecated and will not be there in v3.0. So I just attached the
deprecated.js library and it worked just fine until I ran into this moveend
issue (maybe others as well???) which I thought was unrelated. However, I
have now moved to OpenLayers.Control.Navigation and both map panning and
moveend works. All's well that ends well;-)
Cheers, Brad...
-----Original Message-----
From: Eric Lemoine [mailto:eric.lemoine at camptocamp.com]
Sent: Tuesday, 18 September 2012 4:11 PM
To: Brad Spencer
Cc: openlayers users
Subject: Re: [OpenLayers-Users] moveend Openlayers v2.12
On Tue, Sep 18, 2012 at 12:01 AM, Brad Spencer <brad at numaps.com.au> wrote:
> List,
> I have just upgraded from OL v2.10 to v2.12 and moveend does not
> trigger when I drag the map. Is there a workaround or a patch for
> this?\
I just opened <http://www.openlayers.org/dev/examples/wms.html> and entered
`map.events.on({moveend: function(e) { console.log(e); }});` in the debugger
console, and things work as expected for me.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
