[OpenLayers-Users] Unable to project WFS properly
Smaran Harihar
smaran.harihar at gmail.com
Mon Sep 24 12:05:23 PDT 2012
Hi Phil,
Thanks for the reply. I have declared the WFS like this,
var pimaWFS = new OpenLayers.Layer.Vector("Pima Pine", {
strategies: [new OpenLayers.Strategy.BBOX()],
protocol: new OpenLayers.Protocol.WFS({
url: "http://128.196.142.12:8080/geoserver/wfs",
featureType: "PimaPine",
featureNS: "http://opengeo.org",
srsName: "EPSG:4326"
But still I have no luck despite specifying the srsName.
My Geoserver is 2.1 and seems to be the latest build. How can I check if it
supports WFS 1.1.0 or not??
Thanks,
Smaran
On Thu, Sep 20, 2012 at 2:17 PM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> Unless you use OpenLayers.Protocol.WFS.v1_1_0 and specify the SRS of
> your map in the protocol constructor, then you will be fetching data in
> the native SRS which might not match the map. Does your server support
> WFS 1.1.0? If not then you will have to make sure you have proj4 def
> available on the client and project on the client.
> Notice: This email and any attachments are confidential. If received in
> error please destroy and immediately notify us. Do not copy or disclose the
> contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120924/214abab5/attachment.html>
