[OpenLayers-Users] Add OSM into TileCache
hz hanks
hankshz at gmail.com
Mon Sep 24 17:29:49 PDT 2012
Hey, All:
I want to implement TileCache into my system. I installed TileCache
successfully into my window server and can work well with default
layer ( OpenLayers.Layer.WMS )
Now I want to use OSM layer ( OpenLayers.Layer.OSM ) instead.
I know I need to modify the config file, but things as following don't work:
[osm]
type=Mapnik
mapfile=/home/user/osm-mapnik/osm.xml
spherical_mercator=true
tms_type=google
metatile=yes
Do I need to install Mapnik as well? Or I need to change the value of
"mapfile" in Windows?
Actually, the only thing I need is the cache functionality so I can
use my map application even it's offline. ( The Cache proxy is
installed in the same laptop with the web application, so the web
application can always access to the Cache Proxy ) .
Any suggestion on add OSM into TileCache or any light-weighted
alternative of TileCache?
Thanks a lot!
Best,
Hanks
