[OpenLayers-Users] IE is doesn’t seem to load the map
cheunglucia
cheunglucia at gmail.com
Sun Sep 30 11:14:57 PDT 2012
The map is correctly loaded, it's just hidden somewhere. All you need to do
is to fix the css.
If you remove the positioning, the map will show up.
View this message in context: http://osgeo-org.1560.n6.nabble.com/IE-is-doesn-t-seem-to-load-the-map-tp5005396p5005407.html
