[OpenLayers-Users] HELP! OL 2.13: Google v3 and other layers not zooming "together"
Andreas Hocevar
ahocevar at opengeo.org
Wed Aug 7 05:18:21 PDT 2013
What did you do to turn off zoom animation? On the map, you should use the
following option:
zoomMethod: null
And on the Google layer, you should use
animationEnabled: false
Andreas.
On Wed, Aug 7, 2013 at 2:13 PM, eflow <Jonathan.Wolfe at noaa.gov> wrote:
> Andreas,
> When you turn the animated zooming off, like you suggested in reply #2 to
> this thread. It causes a flicker (blank white screen for ~300ms) on the map
> when you zoom in and out, and doesn't fix the layer not zooming together
> problem either. I was hoping there was a minor change from 2.12 to 2.13+
> that could remedy this behavior, though it may be more complicated than
> that.
> http://osgeo-org.1560.x6.nabble.com/HELP-OL-2-13-Google-v3-and-other-layers-not-zooming-together-tp5060658p5071287.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130807/909553e1/attachment.html>
