[OpenLayers-Users] Canvas issue when using externalGraphic
Alexandre Dubé
adube at mapgears.com
Wed Aug 21 05:36:12 PDT 2013
Hi Xavier,
I just tested the fix and it solves the problem. Would you mind
creating a pull request so that a core dev could review the patch ?
Thanks a lot,
Alexandre
On 13-08-19 09:48 AM, Xavier Mamano (jorix) wrote:
> Hi Alexandre,
> See at:
> https://github.com/jorix/openlayers/commit/aefdde69c620c1dd1497572e17662949e18d5daa
> Xavier
> Alexandre Dubé wrote
>> Xavier,
>> Thank you very much for your efforts. I'm looking forward to see
>> your patch as I don't understand what the issue with the onLoad is.
>> Thanks again,
>> Alexandre
>> On 13-08-18 07:03 PM, Xavier Mamano (jorix) wrote:
>>> Hi Alexandre (second time),
>>> I've had it in front and did not see it, the "onLoad" is the PROBLEM!
>>> I think I can prepare a Canvas.js patch...
>>> Xavier
>>>> Hi Alexandre,
>>>>> but it would still be nice to nail the cause of the issue.
>>>> See: http://jsfiddle.net/jorix/X77cw/
>>>> (after returning from a week in the mountains offline... I extracted the
>>>> code from Canvas.js to set an example of the problem without using
>>>> OpenLayers)
>>>> Try "d1" or "d2", so operates properly.
>>>> But "d1 & d2" not!, the result should be as "d2" (not as d1+d2) :(
>>>> Regards,
>>>> Xavier
>>>>> Xavier,
>>>>> You're right. Thanks for sharing your solutions. I think using
>>>>> your
>>>>> workaround (locking the renderer on unselectAll) combined with a
>>>>> tolerance of 0 could do the trick for me, but it would still be nice to
>>>>> I'll update my example.
>>>>> Thanks again,
>>>>> Alexandre
>>>>> On 13-08-09 04:46 PM, Xavier Mamano (jorix) wrote:
>>>>>> Hi
>>>>>> But the problem remains when the clickout has a little drag before
>>>>>> (less
>>>>>> than 4 pixels --see clickTolerance on OpenLayers.Handler.Feature--)
>>>>>> Try select the features, and unselect by: mousedown + mousemove (less
>>>>>> than 4
>>>>>> pixels) + mouseup. Oops!
>>>>>> Seems that "this.canvas.clearRect (0, 0, width, height);" on
>>>>>> Canvas.redraw
>>>>>> does not act a second time while the js code is still running.
>>>>>> Xavier
>>>>>>> Hi,
>>>>>>> I tried your workaround...
>>>>>>> It works on Chrome but not on FF.
>>>>>>> And tried this:
>>>>>>> select.unselectAll = function(options) {
>>>>>>> vectors.renderer.locked = true;
>>>>>>> OpenLayers.Control.SelectFeature.prototype.unselectAll.apply(
>>>>>>> this, arguments);
>>>>>>> vectors.renderer.locked = false;
>>>>>>> vectors.moveTo(null, true, false); // to force a
>>>>>>> vectors.redraw();
>>>>>>> It works on FF & Chrome.
>>>>>>> Xavier
>>>>>>>> Hi,
>>>>>>>> Here's a pretty dirty workaround:
>>>>>>>> http://dev5.mapgears.com/openlayers/2.12-canvas-issue/examples/canvas-issue-workaround.html?renderer=Canvas
>>>>>>>> In summary, I redraw the layer after features were unselected.
>>>>>>>> I'm still not sure what's the cause of the issue, but I noticed
>>>>>>>> that
>>>>>>>> when calling the unselectAll method of the select control, each
>>>>>>>> feature
>>>>>>>> are drawn (using layer.drawFeature method) separately, resulting in
>>>>>>>> redrawing the layer X times for each feature that were unselected.
>>>>>>>> Maybe if the renderer was locked while unselecting all these it
>>>>>>>> could
>>>>>>>> do
>>>>>>>> the trick.
>>>>>>>> Please, let me know if this should deserve an Issue opened.
>>>>>>>> Alexandre
>>>>>>>> On 13-08-07 01:14 PM, Alexandre Dubé wrote:
>>>>>>>>> Thanks to everyone who tried the example. I'll try to can come up
>>>>>>>>> with a fix or a workaround asap.
>>>>>>>>> Alexandre
>>>>>>>>> On 13-08-07 11:02 AM, Xavier Mamano (jorix) wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I can confirm seeing this using Windows Vista on Chrome, FF, IE9
>>>>>>>>>> and
>>>>>>>>>> Opera
>>>>>>>>>> and olso usign Ubuntu on Chome and FF.
>>>>>>>>>> (using your canvas-issue.html)
>>>>>>>>>> Xavier Mamano
>>>>>>>>>>> Hi,
>>>>>>>>>>> I have an issue when I use Canvas as vector renderer in
>>>>>>>>>>> addition
>>>>>>>>>>> to
>>>>>>>>>>> having externalGraphic properties. I noticed the issue using
>>>>>>>>>>> OpenLayers
>>>>>>>>>>> 2.12, 2.13 and 2.13.1, with the 3 browsers I tested: Chrome,
>>>>>>>>>>> Firefox
>>>>>>>>>>> and
>>>>>>>>>>> IE9.
>>>>>>>>>>> I made a small demo to show the issue 'live':
>>>>>>>>>>> http://dev5.mapgears.com/openlayers/2.12-canvas-issue/examples/canvas-issue.html?renderer=Canvas
>>>>>>>>>>> Before trying to look deeper at the code to see what's
>>>>>>>>>>> going
>>>>>>>>>>> on
>>>>>>>>>>> wrong, I wonder if anyone already hit this same issue and came up
>>>>>>>>>>> with a
>>>>>>>>>>> fix / solution / workaround.
>>>>>>>>>>> Many thanks,
>>>>>>>>>>> Alexandre
>>>>>>>>>>> P.S. The example's html file can be downloaded and added to any
>>>>>>>>>>> local
>>>>>>>>>>> examples folder in order to test it locally with different
>>>>>>>>>>> versions
>>>>>>>>>>> of
>>>>>>>>>>> OpenLayers, i.e. the images and externalGraphic links are
>>>>>>>>>>> absolute,
>>>>>>>>>>> not
>>>>>>>>>>> relative.
>>>>>>>>>>> Alexandre Dubé
>>>>>>>>>>> Mapgears
>>>>>>>>>>> www.mapgears.com
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Users mailing list
>>>>>>>>>>> Users at .osgeo
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>>>>>>>> View this message in context:
>>>>>>>>>> http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5071319.html
>>>>>>>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>>>>>>>> Users mailing list
>>>>>>>> Users at .osgeo
>>>>>>>> Alexandre Dubé
>>>>>>>> Mapgears
>>>>>>>> www.mapgears.com
>>>>>>>> Users mailing list
>>>>>>>> Users at .osgeo
>>>>>> http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5071801.html
>>>>>> Users mailing list
>>>>> Users at .osgeo
>>>>> Alexandre Dubé
>>>>> Mapgears
>>>>> www.mapgears.com
>>>>> Users mailing list
>>>>> Users at .osgeo
>>> http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5073053.html
>>> Users mailing list
>> Users at .osgeo
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Users mailing list
>> Users at .osgeo
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Canvas-issue-when-using-externalGraphic-tp5071099p5073154.html
> Users mailing list
> Users at lists.osgeo.org
Alexandre Dubé
Mapgears
www.mapgears.com
