[OpenLayers-Users] WMS srs error when adding layers from an array
aparker1969
andrew at source3.com
Wed Dec 4 16:18:00 PST 2013
Folks:
I am updating a WMS layer to obtain USGS Topo maps from
"http://basemap.nationalmap.gov/arcgis/services/USGSTopo/MapServer/WmsServer?".
When rendering, the WMS layer throws an error - "Parameter 'srs(crs)' has
wrong value". The problematic map application is at
http://saturn.nmt.edu/national/index.html. The layer is "Topographic Map".
The topo map renders fine in my test map
(http://saturn.nmt.edu/national/basic.html) and in another production map at
http://ford.nmt.edu/prrc_MF/index5.html. [This map is old but still works,
just not in FireFox.]
I think I have narrowed it down to loading the layers into an array then
trying to render the USGS Topo layer. But I cannot figure out way. Any
insight to why this is happening is appreciated.
The getCapabilities of the USGS Topo layer is located at
http://basemap.nationalmap.gov/arcgis/services/USGSTopo/MapServer/WMSServer?request=GetCapabilities&service=WMS
Server: CentOS 5.x
OpenLayers: 2.10
The following are snippets of my array and select code.
/******* CREATE MAP LAYERS ******/
layers = [];
layers.push(new OpenLayers.Layer.WMS("Topographic Map",
"http://basemap.nationalmap.gov/arcgis/services/USGSTopo/MapServer/WmsServer?",
{layers: "0", srs: "EPSG:900913", format: "image/jpeg",
transparent:true},
{isBaseLayer: true, singleTile: false, opacity:1}
var options = {
controls: [],
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
units: "m",
numZoomLevels: 22,
maxResolution: 156543.0339,
// Bounds = Left Bottom Right Top
maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
20037508, 20037508.34)
map1 = new OpenLayers.Map(options);
/********* CREATE mapPanel ******************/
mapPanel = new GeoExt.MapPanel({
//border: true,
region: "center",
center: [-11337475, 4090026],
zoom: 6,
/**************** DEFINE OpenLayers MAP *************/
map: map1,
split:true,
tbar: [toolbarItems]
map1.addLayers(layers);
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-srs-error-when-adding-layers-from-an-array-tp5092831.html
