[OpenLayers-Users] WMS srs error when adding layers from an array
aparker1969 andrew at source3.com
Thu Dec 5 19:30:14 PST 2013
Groovy.  That worked.  Thank +5 and beyond.  I will QA/QC more tomorrow
afternoon.
Off-topic:  I see you are a New Zealander.  We are dog watching for some
friends as they are cycling through NZ.  Been down there a few years ago.
Great country.  If you are ever is Durango, CO USA do not hesitate to call
upon.
Here is what I have:
    layers.push(new OpenLayers.Layer.WMS("Topographic Map",
"http://basemap.nationalmap.gov/arcgis/services/USGSTopo/MapServer/WmsServer?",
        {layers: "0", srs: "EPSG:900913", format: "image/jpeg",
transparent:true},
        {isBaseLayer: true, singleTile: false, opacity:1}
        var options = {
            controls: [],
            projection: new OpenLayers.Projection("EPSG:3857"),
            displayProjection: new OpenLayers.Projection("EPSG:4326"),
            units: "m",
            numZoomLevels: 22,
            maxResolution: 156543.0339,
            // Bounds = Left Bottom Right Top
            maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
                                         20037508, 20037508.34)
        map1 = new OpenLayers.Map(options)
Andrew Parker
Source3 Computing
www.source3.com
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-srs-error-when-adding-layers-from-an-array-tp5092831p5093036.html
