[OpenLayers-Users] OpenLayers and IE11 wfs
Bart van den Eijnden
bartvde at boundlessgeo.com
Wed Dec 11 02:07:43 PST 2013
There seem to be bugs in IE11 XML implementation see also: http://connect.microsoft.com/IE/feedback/details/800941/ie11-rtm-not-correctly-giving-namespace-attributes-with-setattributens
So not sure as yet that this is an OpenLayers issue.
Best regards,
Bart
Front-end Developer | Boundless
@boundlessgeo
On 10 Dec 2013, at 17:35, Ralph Dell <RDell at CatawbaCountyNC.gov> wrote:
> A few weeks ago I posted a problem that I was having with IE11, didn't hear anything back and was able to code an awkward work around for my specific issue
> https://www.mail-archive.com/openlayers-users@lists.osgeo.org/msg11768.html
> Well yesterday I realized I was having a similar issue with the GetFeature control
> I found this solution on the OpenLayers developer list. Thank you Stephen Battey. I am posting it here to make the answer more widely available
> http://osgeo-org.1560.x6.nabble.com/WFS-and-IE-11-td5090636.html
> We override the write method in the OpenLayers.Format.XML class. After the XML has been generated we do a search-replace on the rogue text in the XML namespace.
> Here is the code we run after OpenLayers has loaded:
> var _class = OpenLayers.Format.XML;
> var originalWriteFunction = _class.prototype.write;
> var patchedWriteFunction = function()
> var child = originalWriteFunction.apply( this, arguments );
> // NOTE: Remove the rogue namespaces as one block of text.
> // The second fragment "NS1:" is too small on its own and could cause valid text (in, say, ogc:Literal elements) to be erroneously removed.
> child = child.replace( new RegExp( 'xmlns:NS1="" NS1:', 'g' ), '' );
> return child;
> _class.prototype.write = patchedWriteFunction;
> Ralph Dell
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20131211/a5bc4bed/attachment.html>
