[OpenLayers-Users] OpenLayers.Control.Swipe
Arnd Wippermann
arnd.wippermann at web.de
Mon Feb 11 12:34:03 PST 2013
I used a second way to persuade the SwipeControl to work with
OpenLayers 2.10 and above in a simple example.
I changed Line 402 and 404 in Swipe.js, function clipFirstLayer,
from
var top = -this.map.layerContainerOriginPx.y;
var left = -this.map.layerContainerOriginPx.x;
to
var top = -parseInt(this.map.layerContainerDiv.style.top);
var left = -parseInt(this.map.layerContainerDiv.style.left);
Perhaps it's not the solution, that will work for more complex maps.
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von
Sergeant_york
Gesendet: Montag, 11. Februar 2013 20:48
An: openlayers-users at lists.osgeo.org
Betreff: Re: [OpenLayers-Users] OpenLayers.Control.Swipe
Actually with a bit javascript hackish method you can also make it works
great for 2.11 and 2.12 after initializing map:
/*map initialization here*/
map.layerContainerOriginPx=new Object();
map.layerContainerOriginPx.x=0;//these x and y are the starting
point of your map's div I guess
map.layerContainerOriginPx.y=0;//if it is fullscreen map then x and
y should be 0
/*codes like in above example*/
View this message in context:
http://osgeo-org.1560.n6.nabble.com/OpenLayers-Control-Swipe-tp5032742p50335
46.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
