[OpenLayers-Users] KML icons [workaround / monkeypatch included]
Egil Möller
egil at skytruth.org
Tue Feb 12 06:59:29 PST 2013
It seems to be a pure bug. Here is workaround code:
MapServer.Format.KML = OpenLayers.Class(OpenLayers.Format.KML, {
CLASS_NAME: "MapServer.Format.KML",
parseStyle: function(node) {
var baseURI = node.baseURI.split("?")[0]; // remove query, if any
if (baseURI.lastIndexOf("/") != baseURI.length - 1) {
baseURI = baseURI.substr(0, baseURI.lastIndexOf("/") + 1);
var style =
OpenLayers.Format.KML.prototype.parseStyle.call(this, node);
if (typeof style.externalGraphic != "undefined" &&
style.externalGraphic.match(new RegExp("(^/)|(://)")) == null) {
style.externalGraphic = baseURI + style.externalGraphic;
return style;
Best reards,
Egil
On 02/12/2013 11:30 PM, Egil Möller wrote:
> Hi!
> I'm trying to load KML into a vector layer. The KML contains styles with
> relative paths to icons:
> <IconStyle>
> <color>ff0099ff</color>
> <scale>0.5</scale>
> <heading>496.77</heading>
> <Icon>
> <href>files/vd.png</href>
> </Icon>
> </IconStyle>
> This results in a 404 on http://myserver.com/files/vd.png (the kml file
> is not located in the root of my server...). I've tried to solve this
> using new
> OpenLayers.Format.KML({
> styleBaseUrl: "http://myserver.com/static/kml-files",
> extractStyles: true,
> extractAttributes: true,
> maxDepth: 2
> That makes any errors go away, but no icon markers show up, and when I
> check the network tab in the chrome debugger I don't see vd.png loaded
> at all.
> I actually don't get any errors regardless of what I set styleBaseUrl
> to, as long as it is set.
> Any ideas,
> Egil
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130213/d397b4aa/attachment.html>
