[OpenLayers-Users] Graticule and polar projection
pascal
pascal2833 at gmail.com
Wed Feb 13 08:34:50 PST 2013
I'm trying to add graticules to maps and for the epsg 4326 projection, there
are not problem.
But if I do it with a polar projection (north or south), Openlayers doesn't
draw circles but draw lines to represent latitudes.
This is my code, what's wrong?
var vector_graticule = new OpenLayers.Layer.Vector(
"vector_grat",
{isBaseLayer: false,
projection: new OpenLayers.Projection("EPSG:4326")
graticule_epsgX = new OpenLayers.Control.Graticule ({
intervals: [10, 10, 10, 10, 5, 5, 2, 2, 2], //graticule width in degrees
f(current map zoom levels).
numPoints: 3, // num of points to use in each of the graticule lines.
default: 50.
labelled: true,
//labelFormat: 'd',
targetSize: 2000, //Max size of the grid in pixel on the map. Default:
200.
lineSymbolizer: [{ // Specific syntax. Could be apply to in
vector_graticule, with a "normal" syntax.
fillColor: "yellow",
gratLayer: vector_graticule, // To asociate graticule to a vector layer
(necessary to superpose them to wms).
Thanks a lot,
Pascal.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Graticule-and-polar-projection-tp5034005.html
