[OpenLayers-Users] OpenLayers 2.12 and WMS version 3
Rob Hyx
robhyx at gmail.com
Thu Feb 14 10:06:42 PST 2013
Thanks again for your suggestion. I was able to step through the code and
figure out where it was reversing the coordinates. In the end it didn't
seem like any configuration I made to the layer itself made any different.
By adding: OpenLayers.Projection.defaults['EPSG:4326'].yx = false made it
force not to reverse the coordinates. Can anyone tell me that defaults to
true and / or why the configuration on the layer doesn't seem to make a
difference?
On Thu, Feb 14, 2013 at 11:29 AM, Diego Guidi <diegoguidi at gmail.com> wrote:
> Diego Guidi
> > Thanks for your reply. How do I do that? I tried yx:['EPSG:4326'], but
> that
> > didn't change anything.
> If I remember well you should write
> yx[{['EPSG:4326': true }]
> but it's the same as the default projection, so give a try also to
> yx[{['EPSG:4326': false }]
> or, even better, use openlayers.debug and check how the wms string is build
*HYX*
http://hyx-music.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130214/264c355c/attachment-0001.html>
