[OpenLayers-Users] GetFeature with WFS protocol doesn't return features
Lauri Kajan lauri.kajan at gmail.com
Tue Feb 19 23:23:02 PST 2013
Hi Gery,
The execution never get that far. Featureselected is not triggered.
Problem is in the request method of GetFeature class or actually much
deeper but that httprequest code gets too complex for me to understand.
In the request method of GetFeature class result.features.length is 0 so it
never selects anything.
*Request method of GetFeature class:*
callback: function(result) {
if(result.success()) {
if(result.features.length) {
if(options.single == true) {
this.selectBestFeature(result.features,
bounds.getCenterLonLat(), options);
} else {
this.select(result.features);
-Lauri
On Wed, Feb 20, 2013 at 12:35 AM, Gery . <gamejihou at hotmail.com> wrote:
> perhaps using some:
> console.log("WHAT IT IS GOING ON WITH": feat);
> console.log("WHAT IT IS GOING ON WITH": bbox);
> console.log("WHAT IT IS GOING ON WITH": center);
> can help you to find the error.
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si
> NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken
> Sie es NICHT, wenn es NICHT notwendig ist.
> Date: Wed, 20 Feb 2013 00:31:15 +0200
> From: lauri.kajan at gmail.com
> To: openlayers-users at lists.osgeo.org
> Subject: [OpenLayers-Users] GetFeature with WFS protocol doesn't return
> features
> Hello,
> When I'm trying to use GetFeature control to get features from my WFS run
> into problems. The "featureselected" event never gets triggered.
> I debugged it little bit and found out that the wfs request itself return
> a valid gml and the status code of the request is 200. But still the
> features array of the result object is empty so the code never gets to the
> select method of the GetFeature class.
> Is this something to do with a proxy that I have set?
> I have set OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
> I have configured GetFeature control as follows:
>     var select = new OpenLayers.Control.GetFeature({
>         protocol: OpenLayers.Protocol.WFS({
>                     url:  "**:8080/geoserver/wfs",
>                     featureType: "**",
>                     featureNS: "**",
>                     geometryName: "geom"
>                 click: true,
>                 clickTolerance: 1,
>                 single: true,
>                 hover: false
>     select.events.register("featureselected", this, function(e) {
>         var feat = e.feature;
>         var bbox = feat.geometry.bounds;
>         var center = bbox.getCenterLonLat();
>         map.panTo(center);
> I would appreciate all the help
> Thanks
> -Lauri
> _______________________________________________ Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130220/95629935/attachment.html>
