[OpenLayers-Users] GetFeature with WFS protocol doesn't return features
Lauri Kajan
lauri.kajan at gmail.com
Wed Feb 20 05:59:16 PST 2013
I think I found the reason, but not yet any solution.
Actually the response that wfs-server sent was not valid. It was cutted
after around 23000 characters.
What could affect that. Is it the proxy.cgi that cannot pass longer strings
or is something else?
-Lauri
On Wed, Feb 20, 2013 at 11:04 AM, Gery . <gamejihou at hotmail.com> wrote:
> Hi Lauri,
> not sure but the problem can be related to how the features are called (and
> thus stored) to be then selected. If featureselected never gets triggered,
> that should mean that it is not called. The callback you show what actually
> does? I think taking a look to the whole code will be more useful.
> Regards,
> Gery
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si
> NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken
> Sie es NICHT, wenn es NICHT notwendig ist.
> Date: Wed, 20 Feb 2013 09:23:02 +0200
> From: lauri.kajan at gmail.com
> To: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] GetFeature with WFS protocol doesn't
> return features
> Hi Gery,
> The execution never get that far. Featureselected is not triggered.
> Problem is in the request method of GetFeature class or actually much
> deeper but that httprequest code gets too complex for me to understand.
> In the request method of GetFeature class result.features.length is 0 so
> it never selects anything.
> *Request method of GetFeature class:*
> callback: function(result) {
> if(result.success()) {
> if(result.features.length) {
> if(options.single == true) {
> this.selectBestFeature(result.features,
> bounds.getCenterLonLat(), options);
> } else {
> this.select(result.features);
> -Lauri
> On Wed, Feb 20, 2013 at 12:35 AM, Gery . <gamejihou at hotmail.com> wrote:
> perhaps using some:
> console.log("WHAT IT IS GOING ON WITH": feat);
> console.log("WHAT IT IS GOING ON WITH": bbox);
> console.log("WHAT IT IS GOING ON WITH": center);
> can help you to find the error.
> NO es necesario.
> Date: Wed, 20 Feb 2013 00:31:15 +0200
> Subject: [OpenLayers-Users] GetFeature with WFS protocol doesn't return
> features
> Hello,
> When I'm trying to use GetFeature control to get features from my WFS run
> into problems. The "featureselected" event never gets triggered.
> I debugged it little bit and found out that the wfs request itself return
> a valid gml and the status code of the request is 200. But still the
> features array of the result object is empty so the code never gets to the
> select method of the GetFeature class.
> Is this something to do with a proxy that I have set?
> I have set OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
> I have configured GetFeature control as follows:
> var select = new OpenLayers.Control.GetFeature({
> protocol: OpenLayers.Protocol.WFS({
> url: "**:8080/geoserver/wfs",
> featureType: "**",
> featureNS: "**",
> geometryName: "geom"
> click: true,
> clickTolerance: 1,
> single: true,
> hover: false
> select.events.register("featureselected", this, function(e) {
> var feat = e.feature;
> var bbox = feat.geometry.bounds;
> var center = bbox.getCenterLonLat();
> map.panTo(center);
> I would appreciate all the help
> Thanks
> -Lauri
> _______________________________________________ Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130220/a0e729a3/attachment-0001.html>
