[OpenLayers-Users] Questions on animated zooms.
Andreas Hocevar ahocevar at opengeo.org
Thu Feb 21 06:55:25 PST 2013
A few things to check here:
1) Did you also load the latest style.css from the theme/default/ folder?
2) Does your build include OpenLayers.Tween?
Andreas.
On Thu, Feb 21, 2013 at 11:02 AM, Luís de Sousa
<luis.a.de.sousa at gmail.com> wrote:
> Dear all,
> I've been experimenting with the animated zoom following the examples [1,2].
> With a Google layer as base and a few WMS as overlays it works great, using
> animationEnabled = true for the former and transitionEffect: 'resize' for
> the latter.
> Now when I try the same only with WMS, as base and overlays, the resizing
> works well but there's no smooth transition from one zoom level to another,
> it just leaps abruptly. Do I need to set some some other parameter in the
> base to get the smooth transition?
> Another question I have is on OSM. Is there any animation functionality
> available for it?
> Thank you,
> Luís
> [1] http://openlayers.org/dev/examples/google-v3.html
> [2] http://openlayers.org/dev/examples/transition.html
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Questions-on-animated-zooms-tp5035763.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
